Sharing AOA Calibration over DSAB
Vac
Hi Folks!
If two D-10A's are networked via DSAB, is AOA Calibration from the master shared with the slave or is separate Calibration required for each instrument?
I currently have the master DY-10 calibrated correctly. If a separate Calibration is required for the slave DY-10, can that be performed with the network up and running, or is it necessary to disconnect the slave to perform the AOA Calibration?
Thanks much for any advice!
Mike Vaccaro
RV-4
Niceville, Florida
They both store their own calibrations, so you'll need to do them both individually. SkyView - in contrast - does share settings and calibrations across displays in a multi-display system.
