simple current request
sstearns2
Camarillo, CA
It would be nice if the software could switch the sign of the current. I used the GRT hall effect sensor and I thought I did it right but it diplays -30 amps instead of +30 amps. I just turned the sensor around, but the wiring would have been cleaner if I could have done it with the software.
Scott
DickF
Texas
I have the same request. I just crawled under the panel again to insure the "arrow" is pointing in the correct direction, but yet the +/- indication is incorrect. Is there any other work around other than to re-route the wire?
There isn't currently any other way to reverse the indication.
