Skid/slip ball
GalinHdz
KSGJ/TJBQ
Is it possible to shim the ADAHRS module to get the ball centred?
Peter
It depends if your airplane wings are level or not. The ball must be centered when the wings are level.
:cool:
skysailor
To be honest, the aircraft should be on the ground and leveled using the proper points for the aircraft in question (ie canopy rail, longerons etc). With the aircraft perfectly level only gravity can work on the slip/skid ball and it may be shimmed. I do this in the hangar with jacks and a level for the highest accuracy.
GalinHdz
KSGJ/TJBQ
This is the only way you are 100% sure the wings are level. :cool:
