Skid/Slip Ball
apkp777
My Skyview continually shows me in a skid. The aircraft is in coordinated flight and the ball is off center to the right about 1/2 ball. Is there an adjustment that can fix this? When I step on the ball it is obvious I am uncoordinated and the airspeed drops accordingly.
schristo
what does it show when the airframe is level in both roll and pitch on the ground?
pbennett
The ADAHRS is not aligned correctly. Set up the aircraft as Stephen suggests and shim the ADAHRS to get the ball correct. Theoretically you should get heading and pitch correct too, but you have some latitude there with the SV calibrations.
Peter
apkp777
Sounds like a good plan. I will level the fuselage then alter the alignment. That was my plan, but I was curious if there was some way to correct it digitally through the setup menus.
