SkyView 10' - PFD hangs off when started
IndiaPapa
Double screen system on my brand new CTLS (15h logged). I have a problem with the PFD screan.
The RH side unit starts Ok when turning on the battery switch. After engine start and turning Avionic master the PFD stays frozen with DYNON and Flight Design logo or its screen shows tiny stripes as if the LCD panel was broken..
It takes a few Master Avionics on/offs to get the PFD start OK and go through set up screen
Once I had to do that inflight and I do not like it at all !!
I've not yet tried the 1,2 & 5 reset. Would it help ? Thanks for advice. Irek
The 1/2/5 reset basically accomplishes the same thing as cycling master power. It's the equivalent of hitting the "reset" button on a computer. It does sounds like you have an issue with that display though. Since this is an LSA, you should first get in touch with your local Flight Design representative and have them coordinate with our technical support staff.
