Skyview and the new Garmin GNC255A
JohnH
South Africa
I see that Garmin has launched replacement radios for the famous SL30 and SL40. Does the new GNC255A Nav/Com integrate into the Skyview without the ARINC 429 like the SL30?
In the future releases of Skyview software, are we going to see Flight Director bars with the vertical navigation being spoken about?
Can't say yet about the new radios. We haven't seen tech specs on them (their output/input formats, etc)
On the Flight Director - it's coming!
DS, this may be of help ?--
5.2.4.2.1 Legacy NMEA Support
The GTR/GNC maintains backwards compatibility with legacy SL30/SL40 NMEA commands ($PMMRC
and $PMMRV) as they apply to GTR/GNC functionality.
Serial Port selection:
Selection Description
NONE No unit(s) connected to input/output of this channel.
AVN IN/MAPCOM Serial data transfer with the GTN 6XX/7XX and GNS 400W/500W series.
NMEA Serial data transfer with G500/G600, GPSMap, Aera Series, XL Series, or
GX Series.
Table 6-7. ARINC 429 Configuration Speed (TX)
LO SPEED Standard low-speed ARINC 429 (nominally 12.5 kilobits per second)
HI SPEED High-speed ARINC 429 (nominally 100 kilobits per second)
Let me know if you need more info  :)
Jake J
JohnH
South Africa
Thanks Jake for that info, it is helpful.
I am building an RV7 and have been pricing Avionics options, Dynon Skyview definitely, but I chose an SL30 because of the lower cost of getting it to talk tot he Skyview without ARINC 429.
I am not sure what you mean with Selection Description and the next Line
NONE No units connected to input/output of this channel?
John
Hi John
Selection Description  = description of 3 options below --
1. NONE No unit(s) connected to input/output of this channel.
2. AVN IN/MAPCOM Serial data transfer with the GTN 6XX/7XX and GNS 400W/500W series.
3. NMEA Serial data transfer with G500/G600, GPSMap, Aera Series, XL Series, or
GX Series.
HTH
Jake J
