Skyview Audio
flyingboy
Australia
Guys, I have just connected the Audio output of SV to my Audio input for my headsets. When I go into the Audio set up menu i receive the Audio on each individual setting i.e. Activate the individual alarms no issue and I can adjust the volume without any issue. The problem is i don't get audio when flying i.e. when approaching a way point etc there is no audio. I have been over the manual and settings but maybe I have missed something? Anyone any ideas
Hugh
Do you have multiple displays by chance? And if you do, do you have audio from both hooked up in parallel? If you don't have both displays' audio hooked up, you'd hear audio when in setup (on the connected display) but sometimes you wouldn't hear alerts in flight.
flyingboy
Australia
Yes I do have two screens but from memory I'm taking the audio off one. do I need both to make it work in flight? if yes it looks like i will need to check the wiring
You must have the audio come off both screens or you will experience silence on many of your flights.
