SKYVIEW AUTOPILOT TRIM PROBLEM
Turbo-Dynamic
SkyView D1000 Autopilot Trim Problem
I'm using the SkyView (including Dynon Autopilot Servos) in a Dynamic WT9 - everything works fine expect the triming combined with the Autopilot
Example:
Climbing to 6000ft, Reducing the power to 75%, Trimm the plane correctly
After that engage the Autopilot
Warning from SkyView "Trim Nose Down"
OK, I trim down and down and down until the message on the SkyView is gone
After disengage of the Autopilot the plane moves down extremly hot - clear, because of totaly false trim because of the SkyView message.
Is there a possibility to learn the SkyView how the plane is corretly trimmed??
Ingonring the advise "trim nose down" means the plane flies at correct trim but every few minutes the message "trim nose down"
Or trim according the needs of SkyView with the result of a plane which is absolutely false trimmed
Please HELP...
Hi Turbo (and anyone else experiencing abnormal trim annunciation issues) - can you give our tech support staff a call at 425-402-0433 or email at support at dynonavionics dot com.
lalnaes
Oslo, Norway
I've having the exact same issues. The problem has persisted through all firmware releases since new in June 2010.
