timfwalsh01
OK,
I will ask the question before I hook up power. Want to make sure that the appropriate breaker is a 5 amp one.
SkyView System no battery - 3.5 amps
SkyView with back up battery - 1.5 amps (additional)
I currently have the Skyview, battery, EMS, and GPS antenna.
I use the Approach Stack wire system. It has a label, on a power wire, which shows a 7.5 amps (Pge 4-6 shows this should be sufficient for the majority of the system).
Could you please confirm
Tim
