Skyview EGT jumpy readings then big red X
mikehoover
Out flying yesterday I noticed that my #2 cylinder EGT reading started jumping around, going very high, then red X for a moment then back to normal - repeat, repeat... The erratic behavior is intermittent and when it "settles down" the readings seem normal and in line with the other cylinders. Any ideas for the cause? Thanks!
jdubner
Independence, OR
Coincidentally, I had a similar problem (red "X") on the #2 CHT last week.  The "Sensor Data" screen for the faulty channel showed erratically jumping data and "NaN" (not a number) for the reading.
Mike H. at Dynon tech support suggested checking the crimps at the probe-end of the 25-pin EMS harness.  Sure enough, re-crimping the #2 CHT probe wires fixed the problem.
YMMV but I bet that's it :)
Joe
mikehoover
Thanks for the suggestion Joe. I re-crimped the connectors yesterday and went flying. Seems to have corrected the problem.
