Skyview EMS - No Oil temp on 50% display
Janekom
South Africa
We cannot get the Oil Temp to display correctly ( red cross through it ) on the 50% display. It does work correctly on the other screen sizes.
What dabear said. Go into the SCREEN LAYOUT EDITOR and see if anything weird is going on there (ie, is the oil temp widget under the SENSOR button different between the 50% and other layouts. You might try simply deleting the nonworking one and then re-adding it.
Also, before changing anything, perform a settings backup in case you want to get back to the original state, or if you want, send that file to support at dynonavionics dot com and we can take a look at what's going on in that file too.
