SkyView Engine Data to send to GAMI
jethound
What buttons do I push to download the CHT and EGT values as shown on the Dynon Skyview EMS page.
Do I just take a photo of it. I would like to be able to recall the readout for a time period such as 30 minutes.
Can you help. Can I view these?
Smilin' Jack
jethound
How do I copy the EMS CHT and EGT profiles shown on the Skyview display.
I need to send a readout to GAMI to set my injectors and they said if I can get a readout from the Skyview, then they could analysis it.
Help.
Smilin' Jack
preid
SoCal
get the DATA LOGS under the setup menu (button 7&8), it will have it in a .csv format that GAMI can read.
Also, note that in addition to the data log export, there's another setup menu item under (HOLD BUTTONS 7/8) SETUP MENU > SYSTEM SETUP > DATA LOG SETUP that lets you configure the frequency at which the data is saved to internal memory. The export (to USB memory stick) function that reidvaitor mentioned is under SETUP MENU > SYSTEM SOFTWARE > EXPORT USER DATA LOGS.
