I know that there are bits and pieces of this question scattered all over this board. I would like to request a single consolidated discussion of SkyView - Garmin interoperability. For this discussion assume that all subscriptions are include with the equipment.
Since the current schedule of Version 3 of the Dynon software seems to be 8 weeks or less, lets assume that these answer are based on the current best guess of the functionality of V3 including the mapping subscription.
Assuming you have a standard SkyView configuration (including SV-GPS-250) and for now, no SV-XNPNR-26X transponder. Assume you add a Garmin GTX330 TIS, what functionality have you added to the SkyView?
Now suppose that instead of the GTX330, you configure in a SV-XNPNR-26X. Is the functionality of the SkyView different?
Now let look at GPSs. Same assumptions as above including the Dynon transponder. If you add a Garmin GPSMAP 696, what is the change in the functionality of the SkyView?
Would the answer be the same with an Area 560?
How about the GDU 375?
Now assume that instead of one of the above mentioned Garmin, you use a Garmin GNS 430W / 530W with the SV-ARINC-429. How is the SkyView functionality different?
On to radios. If you connect an SL30 into a SkyView, what is the functionality shift? When you talk about in and out, please help me understand what this means from a function point of view.
What if you used the radio module of the GNS 430W instead of the SL30?
Any updates on the Dynon radio module?
Thanks for any information you can share.
Phil
Phil
