timfwalsh01
Folks,
The settings on the GNS430 are kicking my butt!! I recently upgraded my panel and cannot get the 430 serial data connection to work. I have been through this before with an early Dynon software version.
I added the Dynon ARINC429, and have the latest Dynon software - 2.6
Assuming I connected the 430 wires correctly to the Approach Fast Stack hub (plug and play), and the Skyview settings (serial four) are simple....the 430 is not communicating (no data out. You can tell by the Skyview serial settings Tx and Rx data steams).
Here are the settings I had last time I had the Skyview working with the GNS430 Configuration (software 5.01):
Main ARINC429 Config:
In 1 Speed - Low Data - Off
In 2 Speed - Low Data - Honeywell EFIS
Out Speed - Low Data - GAMA429 Graphics w/Int
SDI Speed - Common
Main RS232 Configuration
Chan 1 Input - Off Output - Aviation
Chan 2 Input - Icarus-Alt Output - Off
Chan 3-5 Input - Off Output - Off
VOR/LOC/GS ARINC429 Config:
Speed RX - Low TX - LOW
SDI RX - Common
DME Directed Freq 1
According to Dynon the settings are suppose to be:
In 1 Speed - High Data - EFIS/Airdata
(I cannot select the "EFIS/Airdata" on the 430 config page, it is in light blue. It will not allow me to use as a setting. I also went into the RS232 Setup - it will not allow me to use)
In 2: Unused
Out Speed - High Data - Gama 429
SDI Common
VOR/LOC/GS ARINC429 config:
TX: High
RX: High
SDI: Common
DME: Not used
Since upgrading, the old settings, nor the new settings are working. Any assistance would be greatly appreciated. Tim
SDI Speed - Common
SDI RX - Common
DME Directed Freq 1
In 2: Unused
SDI Common
TX: High
RX: High
SDI: Common
DME: Not used
