Skyview HDX with VP-X PRO FLAP & TRIM Position Indicator
badia358
Mebane, NC
I have an RV-10 with Dynon Skyview HDX and VP-X PRO. In the Dyon Skyview setup, I have FLAP Position, AILERON TRIM Position and ELEVATOR TRIM Position set to VP-X. In Dynon Skyview Sensor Data, I can see the position values for FLAPS and TRIM change as I move the FLAPS and TRIMS. The position sense wires for FLAPS and TRIMS are connected to the VP-X and NOT to the Skyview EMS.
The FLAPS and TRIMS move up and down, but I cannot get the Skyview Display to show the position at the indicators. When I did the installation, I thought that the VP-X indicated that the position data would be passed to the EMS indicator and based on this I did NOT connect the EMS sense wires (C37-P4 for Elev Position, C37-P22 for FLAPS Position, etc.).
What do I need to fix make the position indicators on the Skyview display work?
Thank you...
WenEng
Spruce Creek Fly-In. Port Orange FL
Sounds like you did not use the Skyview Calibration exercise to establish the trim numbers in Skyview.
Here was the instruction in the Skyview Installation Manual. (Section 7-69 in my version).
"Trim and flaps position potentiometers must be calibrated. Your SkyView display
utilizes onscreen wizards that help you do this. Go to the EMS Calibration Menu to
access these wizards (SETUP MENU > HARDWARE CALIBRATION > EMS
CALIBRATION).
The take-off position will be shown as a green line on the trim widget. If you do
not want this marking on your trim widget, press NONE during the take-off
position portion of the trim calibration."
As I recall once you follow those instructions, you will see the widgets come alive, provided you have placed the widgets onto your screen.
badia358
Mebane, NC
CALIBRATION).
I did the calibration and the calibration worked. The flaps and trims move as calibrated and I can see the changes in value at the sensor debug for the flaps and the trims. I also have the widget on the screen, but the widget does not indication the position. I am sure that if I connect the sense lines from the Skyview EMS to potentiometer, that the widget will show the position, but the VP-X documentation indicates that if in the Skyview menu under VP-X Setup, I select VP-X for FLAPS and TRIM Position, that the widget should work. But it is not working (not indicating).
Thanks you...
badia358
Mebane, NC
Thanks you...
I now have the FLAPS Position indicator working. I found an old posting from from Sep. 6, 2020 that states to remove the EMS FLAPS widget in the editor and then in the editor find a FLAPS selection. I found a selection FLAPS (1). I selected FLAPS Position (1) and now at the bottom of the HDX display, I get a numerical value for flaps position. -3% for reflex, 0%, 20% and 32%.
Will now work on the TRIM position indicators.
Thank you...
Sully73
I am wiring my flaps and trim now. Should I run the position signal through my Dynon HDX or my VP-X Pro? I noticed Dynon has only one pin available for trim position signal on their EMS.
badia358
Mebane, NC
Connect your FLAPS position signal to the VP-X Pro (J1 Pin 17). The TRIM position signals depends if you are installing a SV_AP_Panel. If you are installing an SV_AP_Panel, then connect the Elevator Position Trim (Pitch) to the SV_EMS D37 Pin 4 and you can connect the Roll Trim position signal (if you have a Roll/Aileron trim) to an EMS unused pin like SV_EMS D37 Pin 10.
chriscalandro
You need to select the position sensor associated with the box, not the EMS. It works.
By default the engine monitor pages will use the EMS indication and not the box indication. Remove that one and add the correct one.
Need to calibrate in the VPX, then calibrate in the Dynon.
I use trims and flaps indication, and flaps set points (and slow retract) from the vpx.
The only thing you will want to NOT run through the VPX is your trim control. That needs to be done through the Dynon AP panel. The Dynon will NOT control trim via the VPX and must be done directly. (Indication can be done through either)
