Skyview is freezing up and re-booting during fligh
Doug94
I have about 20 hours on a new Skyview system and all of a sudden it is freezing up.  None of the soft keys took so I cycled via pulling the circuit breaker.  It re-booted a couple of times on its own and froze up again.  Any ideas?  I'm on software ver 5.1
I just checked the MAC address after looking at the tech bulletins and the unit is not affected by one of the circuit boards causing this type of problem.  my MAC address is 00:D0:C9:C8:3B:CA
Update:
I had not flown for about 3 weeks at which time it worked fine. Yesterday (Sat. 5/25) I uploaded the May map updates. This problem has since manifested itself
Two test flights Saturday problem kept occurring
Sunday (5/26): I decided to re-load the Skyview 5.1 software - done. Two test flights today and the problem keeps occurring. Skyview screen freezing up.
I had not calibrated my autopilot so I decided to go through that exercise. Inputted airspeeds required to do the autopilot calibration. Did the stick "thing" full down/left, etc. When it was supposed to test the autopilot servos there is no movement. I suspect this is a result of the skyview failure although I am doing this on the ground with the engine off.
dynon support I will be calling Tuesday morning - hopefully you can help.
