A 10" Screen draws 2.5A at 12V. Each module adds about 100mA at 12V, so an EMS, GPS, and ADAHRS would be 2.8A.
This DOES NOT include battery charging current, which is why we want a 5A fuse. When charging, we can draw 4A, but this is a short term draw. We will not charge the battery unless your alternator is on-line.
If you run two screens, you draw 5.3A, not 5.6A, since each module doesn't add to both screens.
The transponder is it's own load. The specs for the transponder are .3A @ 12V and .4A @12V depending on which power transponder you buy.
