Skyview question - Map displays and track up
Janekom
South Africa
I am wondering if one has to set up the map display for track up or north up for each display size. What I mean is this - should you set up track north in the 80% display, do you need to do it again in the 50% display in order to make all the same?
No, you do not set this per screen size, it is set once for the map in general.
Janekom
South Africa
Thanks - we have set it in flight to track up. Then later on, on the next flight the LH screen was back to north up while the RH screen was still in track up. Is this possible?
The setting syncs between screens, but, remember that if you're in track up, it can be set to go to north up above some zoom setting (customizable under MAP MENU > MAP MODE)
