Hello, I was just about stranded yesterday when my HDX display started freaking out on the way back home. All systems had worked fine previously from new to about 80 hours (new RV7) before the issue began.
The display will report an amber message "STANDBY NETWORK ERROR" and various modules failing (autopilot, knob panel, comm panel, EMS fail) and blanking of portions of the display (with the red X through the section), but only the left portion and bottom strip (Map was unaffected). The errors would come and go quickly (2-5 seconds) and sometimes work for 3-5 minutes and then start up again.
The only change in the aircraft status was that it was left outside over night and there was some light rain, but no water inside at all.
I landed short and ran the network diagnostic, and the error was listed under the main display and referenced Pins 4&8. I ran the setup/reacquire routine again hoping that the system would fix the modules, but no change in the errors.
Appendix A: Maintenance and Troubleshooting in the installation manual mentions that if the error is:
"... listed under a SkyView display listing in the network status page, that
means that the fault is seen on all devices connected to that display, and is likely due to a
connectivity issue at or very near the display in your SkyView Network wiring scheme."
Has anyone experienced anything like this? I'm not sure where to start looking.
Thanks in advance!
Bill
Thanks in advance!
Bill
