I am in the process of installing the SkyView system in my RV-4 and would like to know whether utilizing the existing Amp transducer from the VM1000 being removed is a possibility with the SkyView. I have reviewed the posts and SkyView installation manual describing the GRT CS-01.
The VM1000 Amp transducer is a four wire unit.
- Red is reference voltage at 10 volts DC
- Blk is ground
- Green is reference at 10 Volts DC
- White starts at 5 volts DC and increases 0.036 volts per amp.
Have purchased the Dynon shunt but the VM1000 transducer is installed.
Possible or not?
Thanks in advance for the input!
Tom Brown
- Blk is ground
Possible or not?
Tom Brown
