Skyview wish list
JoshT
I'm still at least a year away from buying my avionics. So I wanted to submit this now so Dynon has time to work on it ;)
I would really like to see (in order of preference):
1. Dual channel ADSB-In (uat and 1090)
2. Yaw Damper on the RV-10
These would really go a long ways toward reaching parity with your competitor. Just a possible future customer's 2 cents.
I'd second that. I think over time the 978 UAT is going to be less and less a common offering from vendors. I think the FAA created a system that's neither flesh, fowl nor good red herring by trying to split "GA" users from the "bigger" planes above FL180. Should have just done like everybody else and use the same 1090 for all.
1090 has some advantages over UAT that will, I think, grow with time...
J
Jrskygod
One thing I'd really like to see is a glare shield mounted angle of attack indicator. I do like the tone but having both the tone and visual would be super. The display on the screen is not only too small but out of sight when I'm concentrating on the approach to land.
rfazio1951
Ok, so while we're at it. I would love another button module, like the auto pilot buttons, but with a small keyboard. Mounted on the console, so you could type in airports or waypoints.
dnhill
SE Texas
I would like the ADS-B weather to show conditions/TAF's for the nearest airport if the destination airport information is not provided.
A way to do this already is to put your cursor on the airport you want and hit NRST then WX. This will show you the closest known WX reports.
gtae07
UAT gives us the weather info and such, but as far as Out goes, I think the majority is using 1090 based on actual users so far.
The FAA does this kind of thing regularly--they say "here's what we think everyone's going to do, so let's write the rules for that"--and then in the real world everyone does something else.  Look at light sport--the FAA genuinely, truly, 100% honest-to-goodness, Scouts' Honor thought that the vast majority of LSA's would look like "fat" Part 103 ultralights, top out under 87kt, and be used primarily for training ultralight pilots*.  They apparently are completely ignorant of human nature and it never occurred to them that the majority of designs were going to cluster right at every limit they set, that they'd be flown most often to get around the asinine medical requirements, and that every trick in the book would be used to push the boundaries while barely keeping within the letter of the law.
I think what's killing UAT for Out is the requirement to keep a "standard" Mode C transponder as well.  That's more equipment and weight, and if you're spending for ADS-B you might as well take the box out if you can.  International compatibility (or more precisely, the lack thereof) may be a factor, too.
Personally I don't see why you'd develop a system that did Out on one and In on the other, and rely on FAA rebroadcasting to get the rest of the traffic.  Dual In capability should have been the baseline.
* See FAA's comments on the final Light Sport rule in the Federal Register...
krw5927
I'd like to (finally) see traffic and weather ported from ADSB-in to Foreflight over Wifi.
Also, while Foreflight is displaying attitude from the ADAHRS, I'd also like to see indicated airspeed and indicated altitude, instead of just GPS groundspeed and altitude.
Mark_Dickens
I wish Dynon would just get on with implementing support for the VPX in the HDX series. I'd like to upgrade to a 10" display, but can't until they do...
Also, a big thumbs up to the keyboard idea above. I have one in my Cirrus and I love it. ;D
cbennet12
Wish granted! The 472 dual band is on the way!
Craig
It's not documented yet (will be next week) but one of the features in 15.1 that just went live on the web to support the SV-ADSB-472 is VPX support on HDX.
Mark_Dickens
Outstanding! Time to finish my new panel design. Thanks
mrdaud
Just a question to Dynon. I noticed you mentioned a 15.1 update. Do you send out email alerts when you post new software updates? I never seem to see anything posted and have to look at the website often to see what has been posted. If I'm missing the alerts, I'll check and see if my email is not set up right, or if you don't send out alerts, it would be a good thing to do.
We do. 15.1 has a little bit of an odd story - it's been posted for the benefit of SV-ADSB-472 installations, but we'll do another broadcast/email shortly about the new software features in tandem with updated documentation.
