Skyview with AOA?
pporter
Does, or can anyone, post a picture of their display with the AOA installed?
woneill
Is this what you're looking for?
Bill
pporter
Hi Bill,
Thank you for the screen shot. Is this your system? Are you able to change the location of the AOA display?
woneill
It's the pilot's PFD in my CTLS if that's what you're asking.
I'm not able to change the location of the AOA on the screen.
I believe that in order for the AOA to appear on the screen you first must calibrate the AOA in flight using the SET UP MENU (Hold buttons 7 & 8 down together).
True - AOA isn't movable (the PFD elements aren't, but the EMS elements are - limitlessly so in fact).
Also true that the AOA display graph does not show up until there is a valid calibration. You can technically turn it on under SETUP > PFD SETUP > ANGLE OF ATTACK, which, if there is no calibration, will show just an empty box.
