These are the available transponder related RS232 input settings for the GTN series. They are repeated for #2 transponder if you were to have two transponders installed. I am assuming Dynon must be outputting TIS in the same format as the GTX series for the GTN's to recognise TIS based traffic from the Skyview system. The setting will likely be either of the last two. Dynon will need to confirm this.
GTX Mode C #1 - Select this format for the GTX 32 transponder #1. Provides status data, altitude data, and flight ID. Choosing this input setting will automatically configure the corresponding channel output to the same setting.
GTX Mode S #1 - Select this format for the GTX 33/33ES transponder #1. Provides status data, ICAO address, and flight ID. Choosing this input setting will automatically configure the corresponding channel output to the same setting.
GTX w/TIS #1 - Select this format for the GTX 33/33ES transponder #1. Provides status data, TIS data, ICAO address, and flight ID. Choosing this input setting will automatically configure the corresponding channel output to the same setting.
Panel GTX w/TIS #1 - Select this format for the GTX 330/330ES transponder #1. This provides TIS data from the panel mount GTX 330/330ES transponder.
