SL30 and Garmin 296
Letpmar
I have a Sportcruiser on order and intend to fit a D100 and 120 and an SL30 and 296 gps can I connect both the SL30 and GPS to the D100 and if so what cables do I need. Also will both inputs work at the same time.
Thanks in advance
Pete
What you do is hook the GPS to the D120 and the SL-30 to the D100. They will both work at the same time and you swap the HSI with a button on the EFIS.
All the connection info is in the D100 install manual. The only cable you need to buy is a data cable for your 296.
Letpmar
Thanks for a very quick response do Dynon sell the data cable direct and does it have a part number
Pete
Letpmar
Pete
Letpmar
Just one more question
Does the HSI drew info from the SL30 and the 296 at the same time or do you have to switch between the 2 modes.
Pete
Dynon does not sell the 296 cable. You will need to buy that from your Garmin dealer.
The HSI will show elements of the VOR and GPS data at the same time, such as ground track from the GPS all the time, and you can do bearing pointers from both at the same time.
We do not show two total HSI's at the same time.
