DougN
I just picked up my airplane which has an SL30 connected to the Dynon D-100 through the serial port. The SL30 is setup to interface with a "Serial" HSI.
I can tune a VOR on the SL30, but I can't set a course on the SL30. When the OBS button is pressed, the OBS light does not light and the ---FLAGGED--- msg appears. The SL30 seems to be in the "show the direct to VOR radial" mode. The HSI correctly points in the direction of the VOR.
On the EFIS, there are no menu choices for setting a course on the HSI either.
Ideas? Is the issue that the SL30 should be setup as if it's standalone rather than as a serial HSI?
Thanks,
Doug N.
Thanks,
Doug N.
