slip ball
robit
Hi to all, I have a small problem, I have installed D-180 and D-100 with AP74 between them, all tree items exactly aligned. On the ground the balls slightly differs but they went out (a half of diameter) in steady and level flight, also a slight bank ( just D-100 ). The question is how to center the slip/skid ball between markers and what causes D-100 banking
despite other static instruments stays still ( ASI,AI,VSI heading )!
Thanks for any tip.
Regards Robert
The key issue to fix first is the balls being off on the ground. This is not adjustable in any way other than rotating the units to level in the panel, unfortunately. From there, we suspect that your in-flight horizon will shape up. If you want some more personal guidance, though, send pictures of what you're seeing both on the ground and in flight to support@dynonavionhics.com so we can see what you're seeing.
