some problem with network Skyview
asedykh
Hi.
Sorry for bad English and best reguards from Russia.
I have SkyView system: D1000, D700, ADAHRS, EMS-221(For R912iS), SV-GPS-250, 2 backup battery and 2 servos.
1.) I connect all devices to network with skyview hub.
When I detecting skyview devices in network this system don't find SV-GPS-250 and find D700 with massage [connecting fault 1/6], but status is READY. and i see on D700 display all information from ADAHRS and EMS-221.
what is that:[connecting fault 1/6]. Where am I read about typical errors?
2.) Also I have WoodComp Prop with CS-5(6) control unit.
This unit have wire for PRM. And I connect this wire to tach wire on R912UL.
EMS-221 in D37 have pins 27 and 28. Is it output signal?
Can I connect wire(for RPM analog signal) from my prop to EMS 221 D37 p 27?
The SV-GPS-250 is not a network device. It does not appear in that list.
SkyView has redundant wires in the network cables. The 1/6 fault means one of the data sets is broken or mis-wired. The system still works because it's using the backup data wires. You need to look at your pins 1&6 throughout the system and see where the error is. You can start by unplugging cables from your modules and see which cable makes the error go away when you unplug it.
If you have a Rotax 912iS, and you are using the EMS-221, yes, pin 27&28 are used for a constant speed propeller. This only works if you are using a 912iS. Page 7-28 in the install guide covers this.
asedykh
Thanks.
But I have new question)
1.) When I download to my SkyView system special files for R912iS (from http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1262907450) I see that: (pic 1)
When I entering in menu sensor mapping, I see that (pic 2)
How I can mapping ping 36,37 to CAN High and CAN Low?
2.) I have fuel pressure sensor p/n 101716 (50 PSI), When I try mapping I have list of sensors. But fuel sensor 101716 is not in this list. Only other sensors. How I can mapping right sensor?
So first of all, have you set your engine type to the 912iS under SETUP > EMS SETUP > ENGINE INFORMATION?
You don't do anything with the mapping on pins 36 and 37. Just leave it blank.
For fuel pressure you select "KAV 50 PSI DIFFERENTIAL (101716-000)” from the pin mapping. If you aren't seeing this, update both your system software and your sensor definitions from our download page at http://www.dynonavionics.com/docs/support_software_SkyView.html.
