Hi, Dynon. I have a problem. I suspect that Dynon Pitot doesn't work.
My configuration is a SkyView system AND an analogic airspeed indicator. Tubes are safeair tubes (green for total pressure, blu for AOA and white for static). I had my system ramp-tested and it was OK (apart from Pitot).
Today I made two 7'' accelerations (just maybe 10/15 kts. before take off) on the runway and both airspeed indicators (SkyView display and United A/S indicator) signed zero.
I checked all the total pressure line and found that the system, bypassing the Pitot, loses only 5 kts. in 4 minutes. I guess this is average.
I then connected the same silicone tube on the Pitot and indication was zero (I previously covered the two small draining holes along the Pitot).
How does the Pitot work? Is it possible for a Dynon Pitot not to work? What may be the problem? Do I have to tighten something on the Pitot?
At what approx. speed the indicator on the EFIS comes alive?
Thanks.
Camillo
Thanks.
Camillo
