Standby network error
LouRubin
I’ve been trying to troubleshoot a error for quite some time. I replaced one of the hubs with a bent pin,however the error still stands.Would disconnecting each connector on the hub one at a time be a possible solution ? It takes about 3 to 5 minutes to get the warning displayed on the HDX.
The SkyView Network status page will tell you the devices that are seeing the network error. From there, you can often deduce which cable or component (s) you need to troubleshoot. Disconnecting from the hub can indeed help identify the problem.
