JurgenRoeland
- Joined
- Oct 12, 2023
- Messages
- 22
Hi Folks,
I have wired my ACS A-510-2 starter switch to the VPX as prescribed PWR pin to jumper J10-1 and the starter annunciator with a 1K 1W resistor in line to pin J2-11
When checking in VPX configurator, I can see the starter on message in device status going to ON when cranking to the ignition position.
I found how to display the VPX starter ON/OFF widget in the engine page and the starter widget also shows ON (red) when cranking. All fine.
When I keep cranking for long time, I don't see any message appearing.
What I'm wondering is how I can see the "Starter Stuck" message on the dynon screen and if I need to configure something extra for that.
I didn't find any info on this in the manual and our friend chatgpt also didn't have a clue what he was talking about.
So my question is
- is any additional configuration required in VPX or Dynon to indicate the "Starter stuck" warning message ?
- can I test this now without an actual starter installed (I only have the starter solenoid so far) ?
thanks in advance,
Jurgen
So my question is
thanks in advance,
Jurgen
