Good Afternoon all,
I modified a straight Dynon Pitot/AOA probe to include static information. I did this by drilling a ring of 12 small holes, at 30 degree intervals, about 30mm distance back from the tip.
I then removed the silicone sealant from the inside of the tube.
I installed another 3/16 inch aluminum tube in the pitot assy and sealed it with PRC-890 B2, by hand application (I crammed it in there) .
After the sealant cured, I added 100mm to the length of the pitot tube by inserting a machined section into the aft end, with more PRC sealant. Inside this, I poured PRC 890 A2 (thinner sealant) .
I pressure tested the pitot, static and AOA and all were intact.
It is installed on an Extra 300L, experimental exhibition, with a Skyview setup. The reason for this: There are no static ports on the Extra 300L, as they were part of the original pitot tube.
So far, the results are quite promising. Airspeed, static and AOA information are working quite well. I have not had the opportunity to test this against another "Extra", but I suspect the information is at least as accurate as stock.
We carefully monitored the altitude information on T/O (many times) and there was no change as the aircraft accelerated. We pulled up to 20 feet and flew the length of the runway accelerating to 140Kts. The altitude did not vary, other than to say we were 20-30 feet higher. So far, so good.
Now, at 4500 feet, we used Dynon GPS altitude as our altimeter. There was about an 80 to 100 foot discrepancy between GPS and absolute (remember S. Florida is at sea level) . We slowed to 90Kts and increased speed to 160Kts. While remaining at 4500 feet GPS ind alt. We did see a drop in indicated altitude of about 50-60 feet, when our speed changed from 90 to 160Kts.
However, I swear we descended a touch... And I believe GPS altitude is not perfectly accurate (but not sure on that one)
What do you guys think?
