During the last couple of flights, the carb temp sensor reading for my HDX became erratic and oscillated up and down randomly during the flight if the temperature inside the carb went below ~45F or so. The range that the temperature reading oscillates between looks to be about minus 20F below the actual carb temperature and the actual carb temp itself. For example if the carb temp is supposed to be 40F, the HDX will show a carb temp reading that is rapidly changing between 20F to 40F over and over again. Pulling the carb heat to increase the temperature above 45F or so will stop the oscillation and show a rising carb temp. It will eventually stablize and read ok at the higher temp. The sensor was new and installed in 2018 during the CI. The sensor has performed flawlessly until the recent flights.
Anyone else experience this? All other EMS readings such as CHTs and EGTs are rock solid so I can't imagine it's a grounding issue? It's strange that the sensor would start working normally if the carb temp is higher than a certain point. Perhaps a bad solder joint inside the sensor itself?
