Support for 2-stroke twin engines?
kvide
Hi,
I’m using your D-180 in an Ultralight fitted with a Rotax 912ULS. Works fine.
Now I’m wondering if an EMS-D10 could be used for a MC-15 Cri-cri with twin dual cylinder 2-strokes?
Everything else seems to be in place except I would need two independent tachometers. D10 has a left and right tachometer input but can they be used independently and at the same time for two separate engines so that the display would show a left and right TACH instead of a TACH and an MAP meter?
Cheers,
Christian
Despite how it looks, there is actually only on RPM input there. We have two pickups so that you can connect both mags on a conventional ignition system, but it can only listen to one at a time (this lets you do your mag run-up check without losing your tach).
Unfortunately, our only solution for two engines is two engine monitors.
