SV 10" Classic Touch-Unable to upload USER LOG files to SAVVY
kurtfly
I have been unable to upload the User Log file to SAVVY since I upgraded to 16.0.4.8437. I contacted SAVVY who said the file had errors in it at the end. He had to delete the end and then he could import, however, every flight had the current date. so, all the flights show up on the same day and in random order. I tried this with 2 different mem sticks on 2 different occasions about a month apart. I tried at least 5 or 6 times to uplaoad the data on both occasions. Alwas get the "Unexpected Error" message. The BLACK BOX file imports good - only the USER LOG file is bad. Anyone else having this problem?
djones
Administrator
This is likely the date bug in version 16.0.4 Load the attached file into all screens in the system to correct the issue.
It won't save the logs already in the system, but should resolve it going forward. You may want to just delete all of the logs
from the system after you export them and start fresh.
  • fix_16.0.4.time_date_incorrect_with_gps_fix.dfg
kurtfly
thank you! I have loaded the file and cleared the data logs. I will fly later this week to test it out.
Thanks,
Kurt
kurtfly
After loading the Patch and clearing out all the User Logs.
I flew today, downloaded, and uploaded logs to SAVVY. All appears to work correctly!
So, now Is it possible to modify the "bad" DATA LOG file? I tried taking a single days flight out of the original USER DATA file and paste it into a new .CSV file. I imported this to SAVVY but it shows the flight on the current day (10/9/2021), not the actual day of flight (8/7/2021)?
Even though the Flight was on 8/7/2021 it will log into SAVVY as 10/9/2021??? Where else can SAVVY be getting the date if not column D "GPS Date & Time"?
There has to be a way to manually manipulate the USER DATA file to fix this.
Thanks,
Kurt
RV8Driver
I have been having the same issue with my datalog export and uploading it to SAVVY. When I export my datalog of multiple flights from the Dynon then upload them to Savvy, they are all dated the same date which is the export date and not the date of the flights. I have the latest software version of the Dynon Skyview Classic 16.4.4.
Any work around to get the date of the flights to upload correctly into Savvy?
