SV 1000 display screen will not come on
Dev
This is the only message that it will display "Corrupt or missing storage device. Please contact Dynon for recovery
assistance".
Dynon support have been very good to me and have airfreighted a new screen to me in South Africa. The new screen gives the same message.
I can't get into the menu by holding 7 & 8 down simultaneously, nothing happens? Holding 1, 2 & 5 down simultaneously, it does reboot and each time with same error message appearing on the screen?
May be some one out there can point me in the right direction?
I had that message once, but a power recycle fixed it. If both screens give the same message, I'd look at the wiring or battery condition as you most likely wouldn't have two bad SV in a row. I got a few strange displays when the power got real low. If your battery is good then perhaps something is drawing too much power from one of the SV pins.
That's incredibly bad luck, and I don't believe there is any known issue that could cause this to happen repeatedly. It looks like you've also emailed our support team - we'll follow up using that method to work with you on figuring this out.
Dev
Thanks they have asked for a picture of the screen.
We have a large time difference. It is only 6:15am morning of 15 Nov this side in the African Bush, will go out in about 1 hour
Dev
This is how the screen appears
  • Skyview.pdf
We have parallel support going via email, so we'll let that path finish out this case. That is definitely hardware though, and incredibly bad luck. Our apologies and thanks for your patience.
Dev
I would like to thank Mike H and the Dynon support team for their help. They have airfreight the repaired screen back to South Africa. Should have it on Monday.
Dev
Pleased to report all ok thanks to Mike H and support team.
You are a great bunch of Guys. Thank you Dev.
