sv-bat-320 unavailable
PTJ
I've owned my very low time RV-14 for about 20 months. The HDX system has performed without issue until two flight ago when my right-hand screen gave me a CAUTION - BACKUP BATT UNAVAILABLE along with BACKUP BATT TEST NEEDED. With a fully functional left-hand screen I flew a local VFR flight for over an hour but the CAUTION never went away. I went into the setup menu and the BACKUP BATTERY STATUS page.
The page shows:
BATTERY CONNECTED (SETTING): YES.
LAST BATTERY SHUTDOWN: ABNORMAL
BATTERY STATUS: 00.00V
CHARGE STATUS: MISSING/FAULT
I've been looking through the Installation and User Guides but haven't found anything that speaks to this.
Any help appreciated,
PJ
PTJ - You could swap the battery with the known good one on the other screen -
Connect a battery charger to the airplane
Turn on the battery master switch & turn off all unnecessary electrics but leave the main screen (with the suspect battery) on for say 4+ hrs
Then check the backup battery status. If the result is still bad then most probably there is a battery fault or it’s 3 wires/connector at the battery.
Or there may be (unlikely IMO 🙏) a problem with the 2nd screen. Let us know how it turns out - It could be helpful for others who may experience the similar symptoms 😉
