jdubner
Please explain why the standard SkyView .DFG file for a Lycoming 4-cylinder engine's MAP sensor seems to indicate a range of 0 - 19.6439 PSI. My gauge indicates much higher than that of course -- perhaps 0 - 40 PSI. Is there some sort of conversion going on?
The applicable entry in the file starts out:
I'm pretty sure this is the entry that's used in my installation (pin 26 of the 37-pin connector).
Thanks,
Joe
Code:
c37_p26={
valid=1
name=MAP
id=100434-000
alarm_type=OFF
range={
max_display=19.6439
min_display=0
range1_valid=1
range1_top=17.6795
range1_bot=0
range1_name=R1
range1_color=GREEN
range2_valid=1
range2_top=18.6617
range2_bot=17.6795
range2_name=R2
range2_color=YELLOW
Thanks,
Joe
