MousnRobin
- Joined
- Oct 9, 2016
- Messages
- 2
Hi all,
I'm trying to configure my Skyview HDX, but I have a problem because the Rotax 915is is not defined. If I use the Rotax 912iS definition (since the EMS221 is meant for both Rotax 912iS and 915iS), then the MAP max values are completely wrong (colours green/yellow/red start at the wrong values), I even get a grey arc between the red and yellow areas!
If I use the "OTHER" option to define the Rotax 915iS myself, then I have a different problem as not all sensors are seen... Is there a way to overcome these issues? When is Dynon planning to bring an update that actually contains the Rotax 915is and its specific values?
Thanks a lot for any suggestions...
Nad
Nad
