SV-GPS-250
llacy
Can I use the SV GPS 250 as a GPS source for my Tru Trak autopilot and if so how do I do the wiring?
If you have a spare TX serial port in the SV then set that to NMEA & connect it to the TT.  The only horizontal hold capability the TT will then have is in HDG mode only, not TRK.  Direct connection from the GPS 250 won't work as the baud rate is far too high.
HTH  ;)
