JurgenRoeland
- Joined
- Oct 12, 2023
- Messages
- 15
Hi all, I am planning on buying the SV-HARNESS-INT harnass for the intercom as it seems too many wires to handle conveniently by myself.
The manual of the intercom states about ground loops and shield grounding :
Because other electrical loads can cause large current flows in a ground path, audio system grounds should be isolated as much as possible from electrical ground. Except where specifically directed in the wiring diagrams above, the shields for all audio cables should terminate at a single point, with that point connected directly to the SV-INTERCOM-2S's MASTER GROUND (Pin 1). Additionally, the point should be as close to the SV-INTERCOM-2S side of your harness as possible
can I assume when I buy the harness that this joining of shield grounds to one point and then to pin 1 is already handled inside the pre-made harnass ?
or should I still open the connector of the harnass and do some kind of magic to bring it all together ?
as it says "as close to the intercom as possible" I assume that this is part of the harness but just want to make sure
