Michel from Switzerland
- Joined
- Aug 19, 2019
- Messages
- 1
Installed new Skyview System 10" with XPNDR-262. It's a new installation in an experimental metal aircraft. I had an avionics specialist check the transponder signal. He measured only 2 Watts transmitting power at the antenna. We thought it might be the antenna cable. But there is 0 resistance on the cable +/- and no short circuit. The antenna is a new RAMI AV-22 from ACS. I installed the latest version of Skyview Software, but did not do any updates to the XPNDR. XPNDR cabling seems right because all information is shown on the skyview screen. I was also able to see the aircraft on flightradar24.com.
What other cause could lead to the low transmitting power at the antenna? Does it depend from the update? How can I find the error?
