Installed a SV42T Pitch Servo using Dynon bracket in my RV-10. The 1/4" rod end supplied is too big to fit into the tapped hole in the forward end of the rail. It does fit the hole in the aft end of the rail. Should I remove the cotter pin and castellated nut and then reverse the rail and pulley to make it work?
