Tacho Time Display
BASmith
Not sure how we did it but the Tacho Display above the Hobbs display has dissapeared. Can you help me get the display back.
Not sure how to put it back.
Many Thanks.
You probably set your engine type to Rotax. Rotax engines don't use tach time for anything so we hide it.
BASmith
Yes you are right, I am using a Rotax 912uls.
Time is still being added when you go to time adjust.
Can I still display the Tacho Time?
If you have Rotax set as your engine type, there is no way to display the tach time. If you want to display this, you'll need to choose "other" as the engine type, and set up your oil temp and RPM limits manually. You'll lose the dynamic RPM based on oil temp function.
Tach time IS still incremented behind the scenes though, and can be viewed in the SETUP menu where it can be changed.
