badia358
I have a Lasar Electronic ignition installed in my RV-6A project. I have not installed the engine eyt, but want to make sure that I am wiring the EMS-220 correctly. I currently have the Right and Left p-leads conneted the EMS D37 connector pins 32 and 33 through a 30K ohm resistor. I noticed in the Laser manual that they provide a wire (brown) for engine RPM.
Does anyone know if the way that I currently have it connected with p-leads through 30K ohm resistor is correct or should I be connecting the Laser RPM brown wire output to a different pin of the EMS D37?
