TAS Now Reading WAY Low
melkel2000
I've been flying my D-180 for about 3 years now with no issues...or so I thought.
About a year ago, I noticed that my TAS was indicating about 4-5 mph slower than what was "normal" in my airplane. I didn't worry about it too much but I always wondered why this happened.
Fast forward to yesterday. My TAS was showing 20+ mph low plus the winds were all wonky, showing very high at one point and showing a tail wind in opposite directions (every pilot's dream). I took the plane down yesterday after my flight to complete my condition inspection so it's good timing.
After reading some posts, I suspect a leak in the system. I'm thinking it's something that has been wearing or loosening over time.
My question is, if a leak is the likely culprit, is the pitot line or the static line more suspect?
By the way, this is installed in an RV-9A.
kurtfly
TAS needs Indicated Air Speed, Temperature, and Pressure altitude.
Is the IAS also ~20 kts low?  Look at these to determine the root cause.
Static leaks can usually be proven by opening / closing air vents when in flight. If you see a change in altitude when opening or closing an air vent you have a leak.
rvator51
Peoria, AZ
I am not sure what is most likely, but I also wonder if you should check for condensation in your lines too?
GalinHdz
KSGJ/TJBQ
If only your TAS is off then the problem is probably in the Pitot system. If both your TAS and altitude is off then the problem is in the static system.
:cool:
melkel2000
Well, I finally got around to working on the plane last weekend. I started with the easiest pitot connection to get to (in the wing) checked for the security of the lines, and this is what I found:
Yep, that was the problem. I'm not sure how it pulled out from the back of the connector. Weird, but I replaced the connection hardware and everything works fine again.
Thanks for the help.
