Taxi plate won't show actual location aircraft
mdragon
I've been having this issue for months. Wondering if anybody knows the cause. I use Seattle avionics for airport taxi information. Lately, it shows the magenta airplane that indicates location significantly off from actual location when the taxi diagrams pulled up. Sometimes a mile away from where the airplane actually is. Despite updating the Seattle avionics database several times, the problem persists. Any ideas?
GPS shows a very specific latitude and longitude and appears to be properly synced with satellites when this occurs.
Most likely the plate. False positions for GPS are usually due to cycle slips, such as a millisecond interrupt slip which will cause a 300 km sudden jump in position followed by a return to the correct location. The GPS solution is pretty robust and if it were wrong on a plate, it'd likely be wrong on all mapping.
My guess...the georeferencing data on the plate is bad. It happens.
