temperature probe
It is the same probe with a different connector, so it can be used on SkyView, but not shared between the SkyView and the D10A at the same time. They both power the sensor and that will mess up readings, plus there would be no redundancy.
The SkyView ADAHRS purchase price includes an OAT probe, FYI.
Ron_B
If you have two ADAHRS do you have to install both OAT plus the one for the Skyview. I have one installed in a wing thinking the Skyview was like the D100 series. Where should I connect that OAT probe?
Ron
schristo
the temperature probe for the skyview has to plug directly into the adahrs module... the 'extra' one that comes with the ems harness can drop into the ems220 for any interesting temperature that you care to look at... i used it for cabin temperature.
As Stephen says, you must plug the OAT into the ADAHRS. If you have two ADAHRS units, you need to install two OATs. If you don't, you have no redundancy on OAT (which is used for a lot of calculations).
The SkyView screens don't have an OAT connection, so you never run the connection to the screen. If you do want to use an OAT for something other than OAT (cabin temp, firewall temp, etc), you can run it to the EMS module and use it there.
