Terrain Colors
apkp777
I have been flying with Skyview for quite some time and while normally I fly in relatively flat terrain (WI and FL) I have taken the plane back and forth across the Appalachians many, many times. Yesterday on my flight across the Apps. I noticed that I was not seeing terrain warning colors (yellow set to appear 300feet below me and red 100ft). I have noticed in the past that they were very accurate and the warning colors appeared when I expected them. This time they did not. In fact, with the Red warning color set to appear at 100 feet below my aircraft, I descended to about 4950 and did not see any colors (600 feet below terrain). The pic below, I had climbed to 5350 ft while next to a 5580ft peak (as depicted on the sectional) and was not seeing any Red or Yellow terrain indications. I was perplexed and surprised. I can only assume that my indicated altitude (baro set auto by Skyview and IFR certified system) was significantly off by GPS altitude? This was VERY alarming to me. I did not check my Indicated GPS altitude. I wish I would have. Next time I will.
Does anyone have any input on this?
apkp777
gtae07
I'm hesitant to ask, and I'm sure you checked... but are you sure you didn't accidentally disable the terrain warning?
Also, if you updated you terrain, make sure all of the low, very low and high resolution databases are installed in SETUP MENU > LOCAL DISPLAY SETUP > INSTALLED DATABASES > TERRAIN DATABASES.
