Touch Panel Fault on a non Touch Skyview display
ESM
I have this persistent caution TOUCH PANEL FAULT coming up and can't make it go away, either by acknowledging or by disabling the Touch Hardware in the system setup menu (wonder why this Touch Panel menu even shows up as it is not a Skyview Touch display I have). I also upgraded the firmware to the latest version, no luck there either.
Any ideas how to remove this "caution" since it is blocking out any messages that might come up?
This can happen if you load a settings file from a touch screen on a non-touch. We can get you a simple file to load on Monday that will fix this.
W
William_Ince
Dynon does it again!
Excellent and timely tech support.
Thank you Dynon. :)
Here is the file you can load that will remove this warning from a non-touch device.
Updated 7/11/2016 - new file for newer SW versions. Old one will not work with newer versions.
  • remove_touch_warning_on_non_touch_display.dfg
