Transponder Antenna Location
Bruce
SV in two airplanes
What is the minimum distance required between the transponder antenna and the ADAHRS (magnetometer) in a composite fuselage?  Same question for the SV-GPS-250 separation from the transponder antenna?
Thanks.
The transponder will not interfere with the magnetometer electrically, only the mounting hardware will. I'd keep a foot between them if possible, but less is likely OK.
The GPS should be on the top side of the plane and the transponder antenna on the bottom. You'll have no issues if you do this. If you put them both on the top, you need 2 feet.
